10 years agoHelp: Simple Socket Server - Stratix IV GX
Hello, I have a very basic knowledge on FPGAs and Verilog, as I only started to learn about it this semester. my final year project is quite big as I have to implement a PoE structure then mak...
10 years ago --- Quote Start --- can you try to force your pc to this ip address : 192.168.1.1, gateway is the same as last reply (look above), same for mask. if it still doesnt work, try to force you pc to 1Gb/s or 100M or whatever, but don't let it auto negociate speed. (i read something like this in this forum when someone tried to direct link his pc to his card) i can't really help you further if it doesn't work. I'm sorry. : ( --- Quote End --- Hi I have disabled the DHCP from the BSP editor. Then gave a static IP of 192.168.1.234, then I run it and here are the results, I have noticed that LED D23 keeps blinking and the RX LED of ENET is blinking too but what does that "yyyyyyyyyyy" mean ????!!!
