10 years agoHelp: Simple Socket Server - Stratix IV GX
Hello, I have a very basic knowledge on FPGAs and Verilog, as I only started to learn about it this semester. my final year project is quite big as I have to implement a PoE structure then mak...
10 years agoi think you don't understand what you are doing there. If you disable tse how could your ethernet link work?
In your case, you have to put IP address directly like this (network_utilities.c) : (i'm not sure since i use dhcp)
int get_ip_addr(alt_iniche_dev *p_dev,
ip_addr* ipaddr,
ip_addr* netmask,
ip_addr* gw,
int* use_dhcp)
IP4_ADDR(*ipaddr, 192, 168, 1, 100);
IP4_ADDR(*gw, 192, 168, 1, 254);
IP4_ADDR(*netmask, 255, 255, 255, 0);
/* Non-standard API: return 1 for success */
return 1;
and yes you should replace the section of code i gave to you, and this one above too. please read this before trying to continue your project, you need some basis ftp://ftp.altera.com/up/pub/altera_material/12.0/tutorials/de4/using_triple_speed_ethernet.pdf
