10 years agoHelp: Simple Socket Server - Stratix IV GX
Hello, I have a very basic knowledge on FPGAs and Verilog, as I only started to learn about it this semester. my final year project is quite big as I have to implement a PoE structure then mak...
10 years ago1-is the FPGA connected to a switch or directly to your pc?
2-if it s connected to a switch, ask your admin to give you a mac address related to a IP/DHCP, he will it give to you. 3- GO Qsys and disable PCS options in tse, since you re using an external phy 4- For mac address in software, this example assumes you have this info in an external flash, but you can override it with this (network_utilities.c):
error_t get_board_mac_addr(unsigned char mac_addr)
error_t error = 0;
alt_u32 signature;
mac_addr = 0x00;
mac_addr = 0x07;
mac_addr = 0xED;
mac_addr = 0xFF;
mac_addr = 0x0C;
mac_addr = 0x83;
return error;
replace with mac address you get from your sys admin. the problem should be resolved then
