15 years agohelp plz!
when i try to build my project it fails and i get the message below. what should i do? --- Quote Start --- make -s all includes Compiling hello_world.c... Linking pwm_nios_ii.elf...
15 years agoi used alt_main instead of main in my C code and that solved the problem but i still can't connect to the processor... everytime i try to download the binary code by using run as NIOS II hardware It fails and I got the same message :
--- Quote Start --- Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused --- Quote End --- I will never finish this project on time :(
