17 years agoHelp please. Setting a host name innichestack
I am develping an application based on the Simple Socket Server example and it works fine with a static IP address. I want to use DHCP in the final design, but have a problem in that the only connect...
16 years agoMatthew
Thanks for your reply. My code was very similar but I had screwed up with the port numbers. I had was sending it to a different port than what I was listening on. d-ooh! Hence the name Dumass. Most commonly pronounced Dumb-***. I'm grateful to you all out there, who are willing to lend a helping hand.
