17 years agoHelp please. Setting a host name innichestack
I am develping an application based on the Simple Socket Server example and it works fine with a static IP address. I want to use DHCP in the final design, but have a problem in that the only connect...
16 years agoI am trying to accomplish the same thing. I can't seem to get it to recieve any UDP messages. Would you mind explaining what settings you needed or how you did it.
