15 years agohelp: nios2 "No project templates available"
Hi there! I am a starter of nios2 ide, now I've got a problem in creating a new project. I am using the ubuntu10.04 OS,and quartus9.1sp2,nios ide 9.1. when I'm trying to create a new ...
15 years agoLooks like it is assuming the directories are relative to your home directory instead of the (desired) absolute paths.
Possibly you can fool it by adding a symlink from ~/opt to /opt however you'll probably find it want to write all over its install tree - so you might need a private copy anyway.
