15 years agoHelp neded debugging hardware cycloneII
The guy who designed this has long gone... The board has an EP2C35, along with 64K serial flash, 256K x 36 SRAM and a small EEPROM. The board is programmed using USB Blaster via JTAG running under...
15 years agoPlenty of views but no help.... Is there anyone out there that could supply files to load via USB Blaster that runs the memory test mentioned in the NIOS2EDS software examples. ? I don't have a clue how to do it :(
