15 years agohelp me please!!! alt_flash_open_dev return error
I use sst flash 39vf6401 on my borad.When I need to progamme the flash, I should add a CFI table .Then I can download the programme to the flash successfully. But I can not open the flash whil...
15 years agoHi
Can you run the memory test - take altera example. It wil show whether you hvae problems with EPCS. Maybe it is some hw problem or pins connection- you have your custom board. You should check from the software side too - i remind you should use not reduced device drivers (or reduced, i don't remember exactly this should be on altera web-site). Aslo check if epcs device is initialized as the device in the alt_sys_init.c function. Let me know if you solved your problem.
