15 years agohelp me please!!! alt_flash_open_dev return error
I use sst flash 39vf6401 on my borad.When I need to progamme the flash, I should add a CFI table .Then I can download the programme to the flash successfully. But I can not open the flash whil...
15 years agoYou've got all the C source for the code you are running - so you should be able to track down which test is failing - so what data is incorrect. No one else can know!
