12 years agohelp creating dtb
I'm trying to create my own Quartus project for a Teraisc DE1-SoC board, and I'm stuck generating the bootloader. My end goal is to create a new SD card image that can boot the board with my own desi...
10 years agoHi,
After compiling your kernel, check this directory: /arch/arm/boot/dts copy these three files: - skeleton.dtsi - socfpga.dtsi - socfpga_cyclone5.dts Now from the Embedded Command Shell, compile these files into a single .dtb file: dtc -I dts -O dtb -o socfpga.dtb socfpga_cyclone5.dts Copy the generated socfpga.dtb to your SD card and you should be able to boot kernel. I tried this with kernel version 3.10-ltsi, and I think all kernel versions come with .dts files. https://github.com/altera-opensource/linux-socfpga You can edit the socfpga_cyclone5.dts file and add the entries you need and then compile it again. Note: you can use the sopc2dts.exe with your .sopcinfo (you get the dts file) to get the dts entries of your FPGA module.
