15 years agoHELP!!- NiosII Error message and customized SRAM
Hi, I am a beginner on NiosII. I was recently attracted very much by new features provide by series of new development tools. I am currently facing two problems. I have spent more than one wee...
15 years agoHi HJS,
Thanks for your reply and attachment. There are only two types of SOPC provided SRAM controllers which don't fit the SRAM that I use. So I have to create my own SRAM controller. Yes, I finally learnt that HDL file is not mandantory for creating own SRAM controller. I finally figured out the root cause of my problem. In Quartus II, I defined the pin direction of DATA as output which should be bidir actually. After I used right pin direction definition, the SRAM controller works well. I don't know why QuartusII doesn't report error or warning when pin direction of self-defined component is not in line with Quartus definition. I think this should be bug or at least it is something that should improve. During this period of study, I did find some bugs for SOPC, NiosII. They can be repeated. I will summarize all of these and then send to Altera. I hope these problems can be solved soon to make sure the software are stable and not so buggy. Regarding to problem of# 1, I suspect it is related to NiosII itself. I will consult to Altera for details. By the way, do you have the same problem? It seems to me that it always happen. It is not related to what components I build. Thanks again.
