15 years agoHELP!!- NiosII Error message and customized SRAM
Hi, I am a beginner on NiosII. I was recently attracted very much by new features provide by series of new development tools. I am currently facing two problems. I have spent more than one wee...
15 years agoThanks Daixiwen for your reply.
I didn't find where I can select what signals I want SOPC to export if they are not defined as "conduit_end export" Yes, I did tried to run SRAM memory test program. But I could not make it working. When run, it always stops with the error "ELF downloading process failed". I will try again. Using Signaltap probes is a good idea. Thanks again.
