10 years agoHello world and simple led blink does not work
I created a Qsys system with NIOS, JTAG UART, On-chip memory(50 KB), PIO_OUT and assigned base addresses. Successfully programmed the sof file onto target board. Now went on creating a simple hell...
10 years agoPerhaps adding the diagram of code, or the top layer design could give additional info. Have you tried to start a new template design from BSP ? At least this way you could implement the solution incrementally, just adding extra functionalities at a working design.
