15 years agoHello MicroC/OS-II problem
Firstly, I'm totally new to MicroC/OS and FPGA's in general, so no doubt this will be a no brainier for everyone else. I'm using a Cyclone II on a "DE2" board. Up to this point, I had a small b...
15 years agoI was using the default Altera drivers (are they thread safe?)...but to be sure I removed them totally and set STDOUT to the JTAG UART. Still no luck, though I don't think it actually stops... I've single stepped through the code and it seems to be sat in a loop waiting for the next task to run, without ever starting one. It grabs a semaphore, looks for any waiting tasks, then releases it. (repeat)
This is odd as like I said before, I'm trying to use the default "Hello uCos" application, so have made no code changes...But it never seems to run the two default tasks. Perhaps I should start a new project with the minimal hardware, I've had lot's of issue's with the NIOS SBT for Eclipse "cashing" files and leaving projects dirty.
