16 years agohello micro c osii
I am trying to get the hello world example for micro c osii to work on my board. I have a custom board with a cyclone III 120 on it. I have a serial flash and two sdrams hooked up as well as an onbo...
16 years agothe code is getting stuck checking for active interrupts in alt_irq_handler().
there is always interrupt 16 pending. When the ISR for this irq is called, the interrupt is never cleared and the program hangs. This is bit 4. I have IRQ 4 assigned to a full featured 1us timer core. Can anyone help me with this. I am getting stuck before hitting main() inside alt_irq_handler() with my timer always interrupting. I am using the standard hello microc osII project with the correct timer and jtaguart cores specified in the library settings. does this project expect a ms timer?
