MChar30
6 years agoHello, I usually work with the 18.1 standard version under Window 10. When I create a new project under Nios II Eclipse I find this error : Denied access to Makefile. Can you please help me for this bug ? Thank you
With the same PC, I have reinstalled Quartus, changed with a new simpler file.spcinfo and the problem is the same. I have installed Quartus Lite 18.1 on another PC with window. I can create and com...
TerryD_Altera
6 years agoI ran into this issue in the past and have worked around this by running the Nios II Software Build Tools for Eclipse as Administratior (Right-Click, More--> Run as administrator).
Hopefully this works for you.
TD
