ASey's avatar
ASey
7 years ago
[Hardware Testing]How to connect the jtag-MM in Top level. ref. [Low Latency Ethernet 10G MAC Intel Cyclone 10 GX FPGA IP Design Example User Guide]
I need some help. I want to know what is error and how to do it.
​Where should I check?
If anyone has ever run a demo board, please help me.
Thanks in advance
<Used cyclone 10gx DEV>
[Top file in sample project]
module altera_eth_top # (
parameter NUM_CHANNELS = 2,
parameter DEVICE_FAMILY = "Cyclone 10 GX"
input wire csr_clk,
output wire core_clk_312,
input wire ref_clk_clk,
input wire master_reset_n,
output wire sfp0_txdisable,
output wire sfp1_txdisable,
output wire xfp_txdisable,
output wire [1:0] SFPP0_RATE_SEL,
output wire [1:0] SFPP1_RATE_SEL,
// LED
output wire [NUM_CHANNELS-1:0] block_lock_n,
output wire [NUM_CHANNELS-1:0] tx_ready_export_n,
output wire [NUM_CHANNELS-1:0] rx_ready_export_n,
// debug clock
output wire core_clk_156,
output wire [NUM_CHANNELS-1:0] tx_serial_data,
input wire [NUM_CHANNELS-1:0] rx_serial_data,
output wire core_pll_locked_n,
output wire atx_pll_locked_n,
output wire [NUM_CHANNELS-1:0] avalon_st_rxstatus_valid_156,
output wire [NUM_CHANNELS-1:0][39:0] avalon_st_rxstatus_data_156,
output wire [NUM_CHANNELS-1:0][6:0] avalon_st_rxstatus_error_156
wire csr_rst_n;
wire tx_rst_n;
wire rx_rst_n;
wire [NUM_CHANNELS-1:0] block_lock;
wire [NUM_CHANNELS-1:0] tx_ready_export;
wire [NUM_CHANNELS-1:0] rx_ready_export;
wire core_pll_locked;
wire atx_pll_locked;
assign csr_rst_n = master_reset_n;
assign tx_rst_n = master_reset_n;
assign rx_rst_n = master_reset_n;
assign sfp0_txdisable = 1'b0;
assign sfp1_txdisable = 1'b0;
assign xfp_txdisable= 1'b0;
assign SFPP0_RATE_SEL = 2'b11;
assign SFPP1_RATE_SEL = 2'b11;
assign block_lock_n = ~block_lock;
assign tx_ready_export_n = ~tx_ready_export;
assign rx_ready_export_n = ~rx_ready_export;
assign core_pll_locked_n = ~core_pll_locked;
assign atx_pll_locked_n = ~atx_pll_locked;
altera_eth_10g_mac_base_r #(
.NUM_CHANNELS(NUM_CHANNELS),
.DEVICE_FAMILY(DEVICE_FAMILY)
) dut_inst (
.csr_clk (csr_clk),
.csr_rst_n (csr_rst_n),
.core_clk_312 (core_clk_312),
.tx_rst_n (tx_rst_n),
.rx_rst_n (rx_rst_n),
.ref_clk_clk (ref_clk_clk),
.core_clk_156 (core_clk_156),
// csr interface
.csr_read (1'b0),
.csr_write (1'b0),
.csr_writedata (32'b0),
.csr_readdata (),
.csr_address (16'b0),
.csr_waitrequest (),
.tx_ready_export (tx_ready_export),
.rx_ready_export (rx_ready_export),
.block_lock (block_lock),
.tx_serial_data (tx_serial_data),
.rx_serial_data (rx_serial_data),
.core_pll_locked (core_pll_locked),
.atx_pll_locked (atx_pll_locked),
.avalon_st_rxstatus_valid_156 (avalon_st_rxstatus_valid_156),
.avalon_st_rxstatus_data_156 (avalon_st_rxstatus_data_156),
.avalon_st_rxstatus_error_156 (avalon_st_rxstatus_error_156)
endmodule
[ To Interface the Jtag]
Add to Top file...........
wire [31:0] jtag_if_address;
wire jtag_if_read;
wire jtag_if_write;
wire [31:0] jtag_if_writedata;
wire [31:0] jtag_if_readdata;
wire jtag_if_readdatavalid;
wire jtag_if_waitrequest;
// JTAG Master
alt_jtag_csr_master jtag_master (
.clk_clk (csr_clk),
.clk_reset_reset (~reset_n),
.master_address (jtag_if_address),
.master_write (jtag_if_write),
.master_read (jtag_if_read),
.master_writedata (jtag_if_writedata),
.master_readdata (jtag_if_readdata),
.master_readdatavalid (jtag_if_readdatavalid),
.master_waitrequest (jtag_if_waitrequest)
After compiling, Run tcl in Tcl console
% pwd
C:/intelFPGA_pro/SNS_Q102
% cd c:/intelFPGA_pro/SNS_Q102/hwtesting/system_console/
% pwd
C:/intelFPGA_pro/SNS_Q102/hwtesting/system_console
% source loopback_conf.tcl
​/devices/10CX220Y@2#USB-1/(link)/JTAG/alt_sld_fab_0_alt_sld_fab_0_sldfabric.node_0/jtag_phy_0.jtag/master
Info: Opened JTAG Master Service
Read loopback status
error: master_read_32: This transaction did not complete in 60 seconds. System Console is giving up.
while executing
"master_read_32 $jtag_master $address_hex 1"
(procedure "rd32" line 6)
invoked from within
"rd32 [expr {$CHANNEL*0x10000 + 0xC000}] 0x800 0x00"
(file "loopback_conf.tcl" line 25)
invoked from within
"source loopback_conf.tcl"
Please. I need your help.
1 Reply
  • Deshi_Intel's avatar
    Deshi_Intel
    Hi Asey,
    I presume you are referring to Cyclone 10 GX 10G Ethernet example design from below link
    If you are using Cyclone 10 dev kit board
    • Then make sure you configure the on board clock generator frequency correctly as per attached pic
    • JTAG master rely on on-board JTAG connection. You want to check to ensure your JTAG connection is working as well. You can use "jtagconfig" command to verify on board JTAG connection or run "jtagconfig --setparam 1 JtagClock 6M" command to reduce JTAG frequency to improve the signal quality
    • You are running Avalon-ST loopback via "source loopback_conf.tcl". This is the loopback where external Ethernet tester generate traffic to FPGA Eth RX pin, loopback internally inside FPGA and then re-transmit back to FPGA Eth tx pin then to Ethernet tester. So, you need to verify your tester setting as well
    else if you are using your own board
    • Then make sure you configure all the FPGA pin assignment correctly and double check your board FPGA power, JTAG, clock and reset connection before you run the Ethernet testing
    dlim
