ASey
7 years ago[Hardware Testing]How to connect the jtag-MM in Top level. ref. [Low Latency Ethernet 10G MAC Intel Cyclone 10 GX FPGA IP Design Example User Guide]
Hi, I need some help. I want to know what is error and how to do it. Where should I check? If anyone has ever run a demo board, please help me. Thanks in advance ------------------------------...
Deshi_Intel
7 years agoHi Asey,
I presume you are referring to Cyclone 10 GX 10G Ethernet example design from below link
If you are using Cyclone 10 dev kit board
- Then make sure you configure the on board clock generator frequency correctly as per attached pic
- JTAG master rely on on-board JTAG connection. You want to check to ensure your JTAG connection is working as well. You can use "jtagconfig" command to verify on board JTAG connection or run "jtagconfig --setparam 1 JtagClock 6M" command to reduce JTAG frequency to improve the signal quality
- You are running Avalon-ST loopback via "source loopback_conf.tcl". This is the loopback where external Ethernet tester generate traffic to FPGA Eth RX pin, loopback internally inside FPGA and then re-transmit back to FPGA Eth tx pin then to Ethernet tester. So, you need to verify your tester setting as well
else if you are using your own board
- Then make sure you configure all the FPGA pin assignment correctly and double check your board FPGA power, JTAG, clock and reset connection before you run the Ethernet testing
dlim
