Rajeshm
4 years agoGetting Error - While Generate the HEX File form .ELF
I'm using the windows machine - Quartus (Quartus Prime 21.1) Lite Edition.
I'm getting an error when trying to convert .elf to a .hex file.
rajesh@rajesh:/mnt/e/project-1/src$ alt-file-co...
EBERLAZARE_I_Intel
4 years agoHi,
To work around this problem, follow the steps below:
1.Please copy boot_loader_cfi.srec from installation path and place it in your NiosII software project folder.
I am unsure where, could you do a "ls" and check if the file is on your current directory "/mnt/e/project-1/src", make sure it is there and re-run the command that you used.
p/s: If you find any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4 or 5 if you ever received a survey.
