21 years agoGERMS in NIOSII
My Question is with GERMS and NIOS II does the command (detailed below) still support writing to flash memory?
M0700000:AAAA AAAA (This is a example write to memory including flash that was used in previous versions of NIOS) Thanks for your help!!11 Replies
--- Quote Start --- originally posted by faizal_kotta@Mar 22 2007, 03:40 PM i would like to add germs in nios ii . i am using quartus verson 6.however when add the legacy on-chip memory and try to genrate it says legacy sdk not enabled. i am not able to do so................. http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/sad.gif
if this is not possible is ther any other alternative method ........ or anything other than germs...........
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22427)
--- quote end ---
--- Quote End --- If you just want GERMS see this link - http://forum.niosforum.com/forum/index.php...c=3754&hl=germs (http://forum.niosforum.com/forum/index.php?showtopic=3754&hl=germs) In Quartus 6 you can reactivate the legacy sdk by editing your system .ptf file - look for the legacy_sdk items, but it is no longer supported and therefore could be removed/broken in a future release.
