15 years agoGenerating Hierarchical Systems in Qsys
hi I implement a top level system, which is a multiprocessor system, with Qsys then generate the top level system for making subsystem's .SOPC file, but it does not make that. I am so confused, ...
15 years agohi
I did every thing in the right flow as you mentioned. I design a hierarchical system in Qsys. In our design we have a "Top Level System" contains 3 subsystems, which each have one processor NiosII, JTAG, and "avalon memory map pipeline bridge". Cod memory of this processors define as "absolute" type, which is maped to a memory in the Top level system by "avalon memory map pipeline bridge ". But I still have problems as below: If we create a .sopcinfo file for a subsystem, and attempt to build a BSP based on that .sopcinfo file, when the BSP or application tries to refer to components in the top level, those references fail. I found this solution for my problem: "you must generate a .sopcinfo from the top-level system, and base the BSP on this .sopcinfo file." Unfortunately, I have only the .sopcinfo file of top-level system.(that means I do not have .sopcinfo file of subsystems!!!). Please help me in this problem. Thanks a lot.
