19 years agogdb-server can't find Cyclone II board
I'm trying to connect to a Cyclone II board using jtagd and nios2-gdb-server-wrapped under Linux.
They seem to find the USBBlaster OK -- the blue LED flashes briefly when I start the gdb-server, but then the gdb-server complains and exits:# ./nios2-gdb-server-wrapped
There are no Nios II CPUs with debug modules available which match the values
specified. Please check that your PLD is correctly configured, downloading a
new SOF file if necessary.# Questions:[list][*]In the message above to what does the phrase "the values specified" refer? I don't see where I specified any values.[*]What command line parameters or config file entries do I need to connect to a Cyclone II demo board? I don't have a .jtag.conf file, and I know the gdb-server tries to read ~/.jtag.conf. Neither did I specify a config file when I started jtagd. [/list]11 Replies
--- Quote Start --- originally posted by grante+nov 1 2006, 01:15 pm--><div class='quotetop'>quote (grante @ nov 1 2006, 01:15 pm)</div>--- quote start ---
<!--quotebegin-hippo@Oct 30 2006, 08:16 PM would you please add a page on nios wiki to describe how to setup the gdb server?
that would be very helpful. http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif --- Quote End --- Done: http://nioswiki.jot.com/wikihome/linuxgdbserver (http://nioswiki.jot.com/wikihome/linuxgdbserver) I see that we're encouranged to "sign our work" on the Wiki, but I've no clue what that means or how to do it. FWIW, my privilege problem was due to the fact that I forgot to make /etc/hotplug/usb/usbblaster executable. Making jtagd suid root didn't work because suid executables ignore the LD_LIBRARY_PATH environment variable. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19059)</div> [/b] --- Quote End --- Thanks. It looks great. I don't understand what they mean by "sign your work", too.
