15 years agogcc-4.1 toolchain on Ubuntu
Hi all, I just successfully built the gcc-4.1 toolchain on my Ubuntu box, it should be mentrioned that gawk is required for building the toolchain (glibc does not compile with mawk whic...
15 years agoHi,
Thank you for updating the Wiki, I also found that after installing gcc-4.3 packages, a symbolic link is required to make the build script happy: sudo ln -s /usr/bin/gcc-3.4 /usr/bin/gcc34 All the best ... - Johannes
