15 years agoFull On-Chip Memory
Hi, I'd like to know how to determine if the memory space of an on-chip memory is full. In my nios II system, I generated an on-chip M4K memory. It's size is 4096 bytes with a 32 bits data...
15 years agoHi Daixiwen and dsl,
Now I understand what happens when I write a string. Thank you. By the way, if will write a continuous bit stream into the memory, if the 4byte space is full will the data automatically be stored in the next 4bytes? Also when I do this: IOWR_32DIRECT(mem1, 0x00, 0x54); and try to read 0x00 until 0x03 i get: 0x00: 54 0x01: 54 0x02: 54 0x03: 54 Why is this so? Thank you.
