15 years agoFull On-Chip Memory
Hi, I'd like to know how to determine if the memory space of an on-chip memory is full. In my nios II system, I generated an on-chip M4K memory. It's size is 4096 bytes with a 32 bits data...
15 years agoHi Thormodo,
--- Quote Start --- Hmm it's not even possible to store a string with this code or by using IOWR(ALTMEMDDR_1_BASE,0x0,(int)"IN") . But as you can see it will only store data in the first word. --- Quote End --- Hmmm.. but the codes that I tried worked. As you can see in my 1st message, I was able to write that string using the standard IOWR. I did not put a "(int)" before the string though. When I read it and printed it out it was successfully printed.
