15 years agoFull On-Chip Memory
Hi, I'd like to know how to determine if the memory space of an on-chip memory is full. In my nios II system, I generated an on-chip M4K memory. It's size is 4096 bytes with a 32 bits data...
15 years agoHi Daixiwen,
Thank you for your reply, I appreciate it. --- Quote Start --- When you do IOWR(ONCHIP_MEMORY2_1_BASE, 0x3fe, "THIS IS TO TEST HOW MUCH DATA CAN A MEMORY SPACE CONTAIN") you don't write the string to the onchip memory, you just write its address, which is a 32-bit word. The size of the string doesn't matter --- Quote End --- So where is the string stored in memory then? Is it the same case in writing bit streams? Where will the DATA be stored in the on-chip memory? You said that I just write the 32-bit word address to the onchip memory, then what happens to the DATA? --- Quote Start --- The IORD/IOWR macros read and write 32 bit words only, and it isn't an address that you give them, but a register number. --- Quote End --- It means that I have 1024 registers, each accessing 4 address spaces in the physical memory? Okay, then how many bits of data is stored in each byte address? it isn't 32bits I assume because FFF (4096) addressable spaces at 32 bits each would give 16,380 bytes of data, whereas the memory module is only 4096 bytes big. --- Quote Start --- When you do IORD(ONCHIP_MEMORY2_1_BASE, 0x3fe), the actual addresses accessed are the 4 bytes at ONCHIP_MEMORY2_1_BASE+4*0x3fe to ONCHIP_MEMORY2_1_BASE+4*0x3fe+3 (0x00011ff8 - 0x00011ffb). --- Quote End --- What is the significance of this? Can you point me to what literature this is found? Thank you very much. Regards,
