16 years agoFtpd error
I have problems with the ftp and I don't know why because before it worked. I work with ubuntu 9.04 and de2-70. When I write the command ftp and the ip destination I receive this error in my host computer:root@WORKGROUP:/home/garcia# ftp 192.168.1.10
Connected to 192.168.1.10.
ftpd: invalid option -- w
Then If I write the command netstat in my target I can see that a ftp communication has received but has finished with the advice of FIN_WAIT2. If someone can suggest me something. Many thanks4 Replies
To Vikonilov
I saw your post about interrupt using button. I meet same problem right now. Is it possible to share the code? Thank you very much. Best Regart - Altera_Forum
Hi vikonilvo,
I checked ftpd with test-nios2 and nios2mmu and didn't see the same issue using centos5. Is this a ubuntu issue? - Hippo - Altera_Forum
Yes, I think that it is an ubuntu issue. I have changed something (I don't know what) and now I don't know how to configure properly. Many thanks for the patience - Altera_Forum
Hi Vikonilov,
My Level is not enough to send Private Messages @@ My Mail is htmin2001 in gmail Thank you very much
