15 years agofreertos - memory used
Hi everybody!
I have installed freeRTOS operating system into a cyclone iii. With this operating system it is possible to assign a piece of the RAM memory for each task. I want to know how much RAM is necessary for run freertos and which size must have the stack. In the declaration of a new task is necessary to use a parameter configMINIMAL_STACK_SIZE, you have tu sum all the possible tasks for calculate the stack size? Many thanks, ifdm3 Replies
How long is a piece of string?
The amount of stack depends on the depth of subroutine calls and the amount of stack space each uses (for local variables etc). It is possible to do static analysis of the object code (or compiler 'asm' listing), but that is difficult if there are potentially recursive functions or indirect calls. Typically any on-stack buffers dominate. Unfortunately the 'try it and see' approach doesn't necessarily work either - as the limit could well be within the error logging for some uncommon failure and/or require an interrupt to occurr when the stack use is already high (one reason for switching stacks on interrupt). - Altera_Forum
although is not possible to calculate size, it can be assumed that each context switch (when the scheduler assign the time to another task ) also the stack content change?
And if this is true, all the stack assigned to a task is copied into another part of the RAM? - Altera_Forum
Basically during a context switch an OS saves the stack pointer into the current process's control block (PCB). It then loads the stack pointer of the new process and excutes a 'return' instruction.
Other registers might be saved in the PCB or on stack, the callee saved registers need not be saved - but may be saved to avoid leaking values from other contexts.
