11 years agoFPGA-SoC on Arrow SoCKit (Fitter error)
Hello Friends, I am trying to learn Embedded System's on on Arrow SoC Board. http://rocketboards.org/foswiki/view/documentation/arrowsockitevaluationboard 1. I following the youtube Art...
11 years agohello There
OK i have download the ghrd design from rocketboard.org -->compile and follow the instruction-->port to board--> its working, i mean LED Glowing in a pattern etc. (1) Then as u mentioned in your post "check the IO-Standards of the related PINs", i assign the same IO std. to my design (HPSFPGA) as in sockit_ghrd design only to LED pins. it add the new error's related to new assignment saying that "Pin LEDR0 is incompatible with I/O bank 3A. it uses I/O standard 2.5 V, which has.....etc". similear to previous error's (2) How do i check .tcl script please put more light on it?. attached is the print-screen of both design's pin planner along with error being generated. Regards kaushal
