21 years agoFPGA design & user program in EPCS?
I'd like to put both my FPGA design and my user code into an EPCS device. I've figured out how to put the FPGA design into the EPCS via JIC file but it's not entirely clear to me how the ...
21 years agoHi Andrew,
> if I set the reset address to RAM or regular flash, wouldn't the CPU crash > when it jumps there and finds garbage. Yes ... if it finds garbage there. I keep a stable boot monitor in the epcs, but I put test code and filesystem images in standard parallel flash. The boot monitor can program the flash much (_MUCH_) faster than the flash programmer (via ethernet). So for test and debug I just load a sof that has the reset address in the parallel flash via JTAG since it's much more convenient. If things go belly up, I hit the hw reset and use the image from the epcs -- I'm just plain lazy I suppose ;-) > wouldn't loading the user program out of the EPCS necessitate a reset > address set to the EPCS? Normally, yes. But I may have misunderstood your original question. So, I think we might be talking apples and oranges. You can have a reset address outside of the epcs then jump into the epcs bootloader -- admittedly a hack -- and not necessarily a good practice ;-) -- although it does work fine ... but this is all for test & debug ... not product. Regards, --Scott
