9 years ago
FPGA configuration and Nios-II application software into the EPCS
I have the design where i have FPGA logic interfacing with Nios-II. I used Quartus Prime 16.1 Standard Edition. I used Cyclone-IV Device EP4CE55.
I want to put the FPGA configuration and Nios-II application software into the EPCS without using EPCS Controller in Qsys. Is there any method to do?
Thanks in advance
Nandish Jasani.
    Thanks for your reply.
    I used Two Nios-II in Qsys, one Nios already interfaced with EPCS Controller, but another is not. But both Nios-II systems are independent configure in a Qsys.
    Nandish Jasani.
    Acutally both nios configured in Autonomous method, both are isolated system and i have only one EPCS Device in my board. EPCS memory used only for one nios. For another i want to use FPGA Memory.
    Nandish Jasani.
    Sorry I am getting confused. You mean one Nios is using EPCS while another is using On-Chip Memory?
    Can you be more precise in describing your problem?
