21 years agoFlash programmer via ethernet
Now that I have ethernet working on my custom board, I'd like to use it to update the board, or at least the flash memory. It is mentioned in the existing board kit docs that board updates via ht...
21 years ago> With u-boot on the \f core, it seems the dcache is not invalidated for
> a flash erase. u-boot is normally run with data cache disabled. Unfortunately, Nios-II does not provide a mechanism to disable the data cache (as many other processors do). Regardless, commands that affect cache coherency are expected to invalidate/flush the data cache as appropriate if the data cache is enabled ... so you should invalidate the appropriate memory regions in your flash_erase() and write_buff() routines. > 'md' does not bypass dcache, and maybe that is the way it should be, Correct. > so what is the proper way to handle this? If flash_erase() and write_buff() do not invalidate the affected memory regions, you can just use bit-31 bypass when specifying the address to the 'md' command. > Does cache_bypass macro just bypass or also update cache? It simply sets bit 31 of the address ... nothing more. The readx/writex macros (i.e. readb/writeb, readw/writew, etc) should be used when possible rather than CACHE_BYPASS. Regards, --Scott BTW: readx/writex are defined in include/asm-nios2/io.h.
