10 years agoFlash Programmer - Error 8, MAX10
Hello, I am trying to write an application into the CFM Space in my Max10 (10M50DAF484C6 on the Development Kit board) made with NIOS2 SBT with the flash programmer and get the error 8. What...
10 years agoThank you for your reply,
I had a look at the .pdf but what i am missing is the option to write the application into CFM. Executing from UFM is working for me but i want to operate without external memory components and execute in the CFM Also i would prefer to write my design with one click into the fpga. I would like to avoid writing an application which copies the data into the CFM. For the flow to program EPCS, i am using internal configuration for the dual-image. Do free to correct me if i am missing something here. Edit: Sorry, i forgot that the flash programmer uses EPCS. I write again when i tried the link. Edit2: EPCS/EPCQ controller is not supported with max10. Ok so i can use this with other FPGA's. Do you have a solution for max10 devices?
