15 years agoFlash offset Nios II Flash Programmer
I would like to know what flash offset address I've to set in the Nios II Flash Programmer GUI. I'm using now 0x800 for the SOF file and no offset for the ELF file. This works fine. But why 0x...
15 years agoThanks slacker. I just tried and you're right. I always used the offset and this also worked but I think the first 0x800 of the serial flash stay empty.
The SOF does not need an offset. Thanks to you description I understand the way the SOF and bootloader are in the EPCS.
