20 years agoFlash made me Crazy for several days.
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif
Hello everyone: I made a board with ep1c6240c8 by myself.Nios 5.1 . The problem is When I use flash programmer. it get out like this: -----------------------------------------------------------------# ! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.# cd D:/altera/kits/programtest/Debug Using cable "ByteBlasterMV [LPT1]",device 1, instance 0x00 Resetting and pausing target processor:OK No CFI table found at address 0x00000000 Why: ----------------------------------------------------------------------- more detail: 1.the hardware list : ep1c6240c8 MT48LC4M32B2-7(sdram can work well). FLASH:AMD29LV641DH-123R and some other hardware like key led..... I have check hardware several times,without something wrong like flash(16 data bus,22 add bus) should connect to ext_share_bus[22..1].reset_n connected to system_reset_n.OE#,CE#,WE#connect to correct place.And checked pin ssignments ......So phy connect and ssignments should be right. 2.SOPC Target Board:Unspecified Board <---Is there something wrong,I suspect whether this would effect flash,because when I chose altera specified board,the flash chip label will be chosen "U6".However "none" in Unspecified Board cpu:niosII/s with JTAG Debug Module and Caches. tri_state_bridge_0 cfi_flash_0 <-----My flash,something made me mad. sysid <-----ug_nios2_flash_programmer.pdf recommand jtag_uart_0 timer_0 timer_1 3.software project Template: Hello_World In System Library Properties dialog: Program memory: cfi_flash_0 Read-only data memory: sdram_0 Read/Write data memroy:sdram_0 Heap memory: sdram_0 Stack Memory: sdram_0 ------------------------------------------------------------------- I don't know what detail I missed,I will clear it later. Thank you again for spending time read this.5 Replies
You need to read the rest of the Nios II Flash Programmer User Guide, specifically the part about making a target board project at the end.
Basically, the flash programmer needs a .sof file that it will download to the Altera to act as a relay between the JTAG and the flash. There's a process, documented in the guide, to create the project for that relay. After creating the project, you add pins for the flash and any other signals (chip enables, for example), assign the pin numbers, and build the project. When you're done, you have a target board project. By putting its directory in your real project's directory, that target board is listed in the SOPC Builder. Select it, regenerate, and then the flash programmer will know what to do. This really needs to be an FAQ. Lots of people miss the target board stuff in the Flash Programmer guide. - Altera_Forum
The target board stuff was deprecated as of 5.1. The target "board" design is no longer needed for successful flash programming. The current editions of the manual clearly state this fact.
Tommy, you do need to spend some more time reading the flash user's guide, but, it probably also makes sense to try the '--debug' option on the nios2-flash-programmer, via CLI. Following is a sample of what you should be seeing:
You will, obviously, get a different message... The output should help you to decide what the issue is... Best Regards, - slacker$ nios2-flash-programmer -c 1 --debug --base=0x0 Using cable "Nios II Evaluation Board ", device 1, instance 0x00 Resetting and pausing target processor: OK Found CFI table in 16 bit mode Raw CFI query table read from device: 0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 20: 51 00 52 00 59 00 02 00 00 00 40 00 00 00 00 00 Q.R.Y.....@..... 30: 00 00 00 00 00 00 27 00 36 00 00 00 00 00 07 00 ......'.6....... 40: 07 00 0A 00 00 00 01 00 05 00 04 00 00 00 17 00 ................ CFI query table read from device: 10: 51 52 59 02 00 40 00 00 00 00 00 27 36 00 00 07 QRY..@.....'6... 20: 07 0A 00 01 05 04 00 17 02 00 05 00 01 7F 00 00 ................ 30: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ CFI extended table read from device: 0: 50 52 49 31 33 08 02 01 01 04 00 00 01 B5 C5 05 PRI13........... 10: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Read autoselect code 0001-227E (in 16 bit mode) No CFI override data for Device size is 8MByte Erase regions are: offset 0: 128 x 64K Device supports AMD style programming algorithm Multi-byte programming with 32 byte buffer Sector erase timeout is 16s Word program timeout is 256us Buffer program timeout is 4ms Leaving target processor paused - Altera_Forum
Thanks,Mike and slacker.
I have tried to make description file for my taget board,I will do it this several days.But there is some problem.My PCB is made by protel,however the description file needs "wirelist" formate. That description consist of: Intro Tab Netlist Tab <----------I don't have this wirelist formate file Flash Memor Tab <-----------Can I only make configure of this,Because The SOPC can't get information for wirelist netlist. Net Tab Devices Tab Groups Tab Pass Throughs Tab Files Tab - Altera_Forum
--- Quote Start --- originally posted by tommycp@Oct 16 2006, 05:36 PM thanks,mike and slacker.i have tried to make description file for my taget board,i will do it this several days.but there is some problem.my pcb is made by protel,however the description file needs "wirelist" formate.
that description consist of:
intro tab
netlist tab <----------i don't have this wirelist formate file
flash memor tab <-----------can i only make configure of this,because the sopc can't get information for wirelist netlist.
net tab
devices tab
groups tab
pass throughs tab
files tab
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18720)
--- quote end ---
--- Quote End --- Have you tried the "flash flow" mentioned on page 7-8 of the QII handbook? I think it should apply to 5.1, though it's probably written for 6.0. Best of luck! - slacker
slacker
And I find that there is some document,saying that:description without netlist can't work (just flash flows,is "flash flow"means justs configure flash,let alone other like:Net TabDevices TabGroups TabPass Throughs Tab Files Tab),unless modify class.ptf,which is generated by description editor. Could anyone kow how to modify or read class.ptf ---------------------------------------------- document I found on net: Flash Programmer Flash only flow failure in IDE—Updated December 19, 2005 The Flash only flow of the Board Description Editor is used to run the Nios II Flash Programmer on a custom board in IDE mode. When the Board Description Editor is run in the Flash Flow only, wherein no board netlist (wirelist) is provided, the resulting PTF file is missing some entries which are required for successful system generation in SOPC Builder. A subsequent attempt to generate in SOPC Builder will issue the following error: C:/altera/quartus51/sopc_builder/bin/europa/e_project.pm 310 CALLED (e_project::device_family) WHERE <=== 'expected exactly one argument' OCCURRED on C:/altera/quartus51/sopc_builder/bin/europa/e_project.pm 1313 Workaround: The workaround is to use the Flash Programmer via command line or hand-edit the board description PTF file as described below after running the Board Description Editor. 1. Run through the Flash Flow of the Board Description Editor as instructed in the Board Description Editor (PDF) chapter of the SOPC Builder Handbook. 2. Close SOPC Builder 3. In a text editor, open the .ptf file created by the Board Description Editor. 4. In the CLASS/BOARD_DEFAULTS section of the .ptf file, add the following entries. o device_family = "<device family>"; suitable values for <device family> are CYCLONE, CYCLONEII, STRATIX, STRATIXII, etc. o For each CFI or EPCS flash entered in the board description, create a REFDES section with an arbitrary base address, such as just "0". o Workaround_example.txt shows an example of the edits. 5. Save and close the .ptf file after making the edits. 6. Re-open the system in SOPC Builder, select the newly created board description in the "Target" section, and then click Generate. ========================================================== CLASS my_1c20_no_wirelist_board { BOARD_DEFAULTS { class = "my_1c20_no_wirelist_board"; class_version = "1.0"; altera_avalon_epcs_flash_controller { reference_designators = "U59"; } altera_avalon_cfi_flash { reference_designators = "U5"; } reference_designators = "U59,U5"; initial_system_file = ""; # >> Add these lines or equivalent << >> device_family = "CYCLONE"; >> REFDES U5 >> { >> base = "0"; >> } >> REFDES U59 >> { >> base = "0"; >> } # >> End add lines << CONFIGURATION user { ========================================================== ---------------------------------------------- thanks --Tommy
