15 years agoFLASH command via NIOS IO.h
Hi, I'd like to activate dynamic protection sectors ( DYB ) of a 16 bits CFI FLASH SG29GL256N, but I'm facing issues with the IOWR_16DIRECT command of the io.h : when I look the FLASH signal...
15 years agoIIRC the nios cpu will always do 32bit transfers to the Avalon slave, with the 4 byte enables being asserted appropriately.
For a 16bit slave there will be a 'bus width adapter' that generates two cycles with the relevant byte enables copied across - even if it means a cycle has active byte enables! (Reads always assert all 4 byte enables.) It might be that you are only tracing the first of the two adjacent cycles!
