euem789
6 years agofile io with NIOS II
Hi all
I wrote a code to read the text file
for implementing in FPGA board (DE1-SOC) with NIOS II ,
but when I build the project, the elf file wasn't generated.
here's my code
- 6 years ago
Hi, Dong Wook
You are right.
However, there is another way, ie using a character-mode device like UART.
Below example is to write characters to a UART called uart1. You can find the device name (/dev/uart1) in the system.h
#include <stdio.h>
#include <string.h>
int main (void)
char* msg = "hello world";
FILE* fp;
fp = fopen ("/dev/uart1", "w");
if (fp!=NULL) { fprintf(fp, "%s",msg); fclose (fp);}
return 0;
Eric
EricMunYew_C_Intel
6 years agoHi, Dong Wook
Can we close the case ? you may open a new case for your next inquiry.
Eric
- euem7896 years ago
Hi, eric
Recently, I'm also new to these kind of community, so I don't know the exact meaning
'close the case' ...? you're talking about
can you tell me in more detail..??
