20 years agoFIFOed Avalon Uart
I have posted the FIFOed avalon UART in the Hardware Projects area. It is the standard UART that comes with Nios but it has additional features such as FIFOs and hardware CTS fifoed avalon uar...
16 years agoIn 9.0.1 version of fifoed_avalon_uart, IRQ threshold logic is broke - can cause an interrupt to go away without user handling, which in turn can cause a lockup in the altera_irq_handler (which expects an IRQ, once asserted, to never to go away without a SW action).
Problem is that USED outputs on the internal FIFOs wrap around when FIFO is full. E.g. lets say you use FIFO depths of 128 and TX IRQ threshold of 1 and keep on sending data to the FIFO, the TXREADY interrupt will be de-asserted when FIFO has at least 1 entry but will be re-asserted when FIFO is full (because USED on TX FIFO will transition from 0x7F to 0); at that point IRQ handler will be called. While in the handler, the FIFO will get drained at least one character, USED will transition 0->0x7F and IRQ will be deasserted. Proper fix is to either use wider USED field on the FIFO (WIDTHU=log2(DEPTH)+1) or to consider FULL flag while looking at USED to determine TXREADY/RXREADY status for generating the interrupt. Here is the fix to mk_em_uart.pm: 1869c1869,1870 < ([e_signal->new ({name => "tx_almost_empty", never_export => 1}), "tx_used <=$Options->{tx_IRQ_Threshold}" ] )if $Options->{use_tx_fifo}; --- > ([e_signal->new ({name => "tx_almost_empty", never_export => 1}), "(tx_used <=$Options->{tx_IRQ_Threshold}) && tx_not_full" ] )if $Options->{use_tx_fifo}; > 1995c1996 < ([e_signal->new ({name => "rx_at_threshold", never_export => 1}), "(rx_used >=$Options->{rx_IRQ_Threshold}) || timer_timout" ] )if $Options->{use_rx_fifo}; --- > ([e_signal->new ({name => "rx_at_threshold", never_export => 1}), "(rx_used >=$Options->{rx_IRQ_Threshold}) || rx_full || timer_timout" ] )if $Options->{use_rx_fifo};
