20 years agoFIFOed Avalon Uart
I have posted the FIFOed avalon UART in the Hardware Projects area. It is the standard UART that comes with Nios but it has additional features such as FIFOs and hardware CTS fifoed avalon uar...
17 years agoHello,
I'm having a problem in the compilation when the RX FIFO depth and TX FIFO depth are different. It seems that there is a bug when generating the VHDL code: If TX FIFO depth is 8 bytes and RX FIFO depth is 16 bytes: Error (10344): VHDL expression error at slot1_uart.vhd(1562): expression has 4 elements, but must have 3 elements If TX FIFO depth is 8 bytes and RX FIFO depth is 32 bytes: Error (10344): VHDL expression error at slot1_uart.vhd(1562): expression has 5 elements, but must have 3 elements And so on.. If the two depths are the same, no error occurs. Is there anyone experiencing the same problem? Thank you.
