20 years agoFIFOed Avalon Uart
I have posted the FIFOed avalon UART in the Hardware Projects area. It is the standard UART that comes with Nios but it has additional features such as FIFOs and hardware CTS fifoed avalon uar...
19 years agoI figured out how to add RTS flow control in hardware using the UART with FIFO's.
Add the FIFO'ed UART component in SOPC builder. Check the configuration box to add RTS & CTS register bits. Generate the system. When it's done generating, open uart.vhd and edit: Look for: rts_n <= NOT rts_control_bit; Comment out this line and add the following: -- Generate RTS
rts_c: process (clk, reset_n)
begin -- process rts_c
if reset_n = '0' then -- asynchronous reset (active low)
rts_n <= '1'; -- 1=OK to send
elsif clk'event and clk = '1' then -- rising clock edge
if (rx_used(rx_used'left) = '0') then -- FIFO is < 1/2 full
rts_n <= '0'; -- inverted at tranceiver
else
rts_n <= '1';
end if;
end if;
end process rts_c; This asserts RTS when the receive FIFO is 1/2 full. Note that reading the RTS bit in the UART register will not reflect the state of the pin. You'd have to find where rts_control_bit is read and substitute rts_n. Note that RTS is inverted at the RS232 tranceiver, so the levels you'll see on the port are reversed from the code. Hope this helps. I tested it & it works well on my system.
