12 years agoFIFOed Avalon Uart reprise
Currently working with Quartus 9.1 and will later move to latest. Need a Uart with FIFOs and found this: http://www.alterawiki.com/wiki/fifoed_avalon_uart Grabbed this from the above link: ...
12 years agoI am experiencing the same problems (zero in rx fifo) I think I have found an error in one of the pm files named: "em_fifoed_uart_qsys.pm", I think this typing error is causing receive fifos to be disabled even if you enable them...
...# enw for fifoed uart $use_tx_fifo = $Options->{use_tx_fifo}; $use_rx_fifo = $use_rx_fifo; $hw_cts = $Options->{hw_cts}; $trans_pin = $Options->{trans_pin}; $fifo_size_tx = $Options->{fifo_size_tx}; $fifo_size_rx = $Options->{fifo_size_rx}; ... I think the line "$use_rx_fifo = $use_rx_fifo;" has a typing error, but when I changed it as "$use_rx_fifo = $Options->{use_rx_fifo};", I cannot make qsys generate the files. It freezes while creating the files. Thanks for any help...
