15 years agoFIFODEPTH in Avalon MM Masters
Hi, I was looking on the MM Masters Template documentation to understand whether the FIFODEPTH parameter are expressed as bits, bytes or multiples of the DATAWIDTH/ADDRESSWIDTH.
What I read is: parameter: FIFODEPTH range: 4, 8, 16, 32, 64, 128 (default 32) description: FIFO depth of the internal buffer. You should set this to be at least twice the MAXBURSTCOUNT value so that the master operates at peak efficiency.No RepliesBe the first to reply
