20 years agoFIFO Interrupt
Hello to all, i've mapped a FIFO into the address space of my NIOS processor. I simply created a non HDL based interface to readout data by just using the IORDDIRECT macro. The FIFO is written...
20 years agohello christian 80
normally you have an irq status register in your component. a bit in this register is set, when an irq happens, e.g. fifo half full, all bits in the status register are cleared, when the status register is read. the irq signal is set in the component, when the irq status register is != 0. e.g. irq <= '1' when irq_status(7 downto 0) /= b"0000_0000" else '0' your irq service routine in c starts normally with irq_service(...) { // read interrupt status register, clears all pending interrupts irq_status = IORD(base, IRQ_STATUS_REGISTER); ... ... }
