here is my code :
# include <stdio.h># include <unistd.h># include <stdlib.h># include <string.h># include <ctype.h>
# include "includes.h"# include "priv/alt_file.h"# include "sys/alt_cache.h"# include "sys/alt_alarm.h"# include "system.h"# include "io.h"# include "alt_types.h"
/*SGDMA Library*/# include <altera_avalon_sgdma.h># include <altera_avalon_sgdma_descriptor.h># include <altera_avalon_sgdma_regs.h>
alt_sgdma_dev * transmit_DMA;
alt_sgdma_dev * receive_DMA;
alt_u32 *tx_ptr;
alt_u32 *rx_ptr;
alt_sgdma_descriptor *desc = (alt_sgdma_descriptor*)INPUT_RAM_BASE ;
alt_sgdma_descriptor *desc1 = (alt_sgdma_descriptor*)OUTPUT_RAM_BASE ;
void init_FFT_sgdma()
/* Open a SG-DMA for MM-->ST and ST-->MM (two SG-DMAs are present) */
transmit_DMA = alt_avalon_sgdma_open("/dev/sgdma_mm_to_st_fft");
receive_DMA = alt_avalon_sgdma_open("/dev/sgdma_st_to_mm_fft");
// Making sure the SG-DMAs were opened correctly
if(transmit_DMA == NULL || receive_DMA == NULL)
printf("Could not open the SG-DMA of FFT\n");
add pointer to the input and output memory.
//tx_ptr pointer on memory where i will write input data
tx_ptr = (alt_u32 *) (INPUT_RAM_BASE+ ALTERA_AVALON_SGDMA_DESCRIPTOR_SIZE);
//rx_ptr pointer on memory where i can read output data
rx_ptr = (alt_u32 *) (OUTPUT_RAM_BASE+ ALTERA_AVALON_SGDMA_DESCRIPTOR_SIZE);
void Hardware_fourier_trans (N)
int i;
alt_8 *s0= (alt_8*)tx_ptr;
for(i = 0; i < N; i++)
tx_ptr
= (alt_u32) (sig); //sig[1024] is array of input Signal
///////* maybe you will face problem whith arrange bytes whish transmit by SGDMA so you should rearrange bytes when you read from memory */
// Construct descriptors in the same input and output memory.
// here i use just one descriptorfor, if you want more than one replace "NULL" with name of next descriptor.
alt_avalon_sgdma_construct_mem_to_stream_desc(desc,NULL,tx_ptr, (alt_u16)4096,0,1,1,0);
alt_avalon_sgdma_construct_stream_to_mem_desc(desc1,NULL,rx_ptr,0,0);
//start transfer data
alt_avalon_sgdma_do_async_transfer(transmit_DMA, desc);
//wait to finish
while (IORD(SGDMA_MM_TO_ST_FFT_BASE,0)!=12) {};
//start receive data
alt_avalon_sgdma_do_async_transfer(receive_DMA, desc1);
while (IORD(SGDMA_ST_TO_MM_FFT_BASE,0)!=14) {};
//wait to finish
short *s1= (alt_8*)rx_ptr;
//calculate amplitude
for (i=0;i<1024;i++) {sig[i]=-1*sqrt(pow(s1[2*i],2)+pow(s1[2*i+1],2));}
int main(void)
init_FFT_sgdma();
return 0;
Good Luck
