16 years agoFft In Sopc
Guyz please help , if u have an idea. Uptil now i made a 64 point FFT using megacore and added it to the sopc as a new component but there are a lot of signals and so it gives me an error when ...
15 years agoHi every body,
to marlon: i am sory for late. for quastion about using 12 and 14. while(IORD(SGDMA_MM_TO_ST_FFT_BASE,0) != 12); while(IORD(SGDMA_ST_TO_MM_FFT_IMAG_BASE,0) != 14); meaning: when i read this number from Status Registers, that mean SGDMA finished transfer data without wrong. to understand exactly what it means you can read this document: ------------------------------------------- "Quartus II Handbook Version 9.1, Volume 5: Embedded Peripherals" available at http://www.altera.com/literature/hb/nios2/n2cpu_nii5v3_05.pdf to read about SGDMA :Page 209 to read about Status Registers bit Map:Page 221 ------------------------------------------- to necsagar: when you start your Project you should use same language in all project. i think you start project in VHDL, So when you add new component (like FFT core) you should add it using VHDL. you can not use my wrapper_FFT file for your FFT component, But you should write new wrapper in VHDL. if you have problem in using FFT core you can read this document: "FFT MegaCore Function User Guide" start from page 21
