14 years agoEthernet roundtrip time with NicheStack & Nios-II
We are using TSE IP with NichStack, MicroC OS-II on Nios-II. FPGA is running a simple UDP host which echoes all packets it gets from client. The client is a PC running real-time OS and connected to FPGA board via direct, crossover Ethernet cable less than 5 ft. Auto-negotiation sets the speed @ 100 Mb. UDP payload is only 128 bytes. Nios-II is running @ 50 MHz on Cyclone IV. SOPC has SGDMA. Both sides have no other processign/loading. The board is running in tethered mode (level 1 debuggin on Nios-II), as we are using OpenCore licenses. We are seeing rather long roundtrip times (in tens of ms) in PC-->FPGA-->PC for each packet. I am looking at AN440 and "Ethernet Acceleration Design", but was wondering if there is seomthing I may be missing here. What is typical roundtrip time for point-to-point Ethernet, real-time (both sides), closed environment like ours? -swguy
