14 years agoEthernet roundtrip time with NicheStack & Nios-II
Hi, We are using TSE IP with NichStack, MicroC OS-II on Nios-II. FPGA is running a simple UDP host which echoes all packets it gets from client. The client is a PC running real-time OS and con...
14 years agoIf you are using the TSE driver with ucOS and the Interniche TCP/IP stack (the default with the Nios IDS) then it is using interrupts.
Are you measuring the delay for several UDP packets or just the first one? The round-trip time for the first UDP packet may be longer because you also need an ARP request and reply. You could also use a sniffer such as Wireshark to see what is happening on the Ethernet level, but I think profiling should give you also a lot of information.
