15 years agoEthernet problem turned out to be a memory / DMA problem
So I have spent a couple weeks trying to troubleshoot Ethernet functionality on my custom board. I finally isolated the problem last night. Ethernet data is getting into the FPGA just fine. I can ...
15 years agoDavid,
I believe that memory test that you're referring to also makes use of a standard Avalon DMA, if you have one in your system. That ~might~ have caught the issue that you saw... Learning is always good, BTW :-) Cheers, Slacker
