15 years agoEthernet problem turned out to be a memory / DMA problem
So I have spent a couple weeks trying to troubleshoot Ethernet functionality on my custom board. I finally isolated the problem last night. Ethernet data is getting into the FPGA just fine. I can ...
15 years agoI'm pretty new at this stuff so I welcome any obvious hints... When I look at my memory map the TLB addresses are at a different address than the DMA stuff.
Where should I be comparing buffer addresses to? I noticed what appeared to be a bug to me in the Linux SGDMA drivers that they appear to grab a 0x400 wide memory range even though their actual control reigster address is much narrower. Hardcoding address offsets between the DMA's seemed to at least let me send data. David
